I meant faster than the SP300v that I currently have.
I probably did not say that very well. I am leaning towards the Mimaki, any things about that machine
good or bad you could share? Thanks Kindley for your help. Tony
I was replying to the second comment about the speed.
Just a disclaimer, I work for a company that sells these machines but I don't get commission or anything like that. I am a tech that works on these machine only.
The New Mimaki's are great machines and are built to last. They are fairly easy to use and maintain. The output is going to match or outperform most large format digital Epson based printers on the market. I personally believe they outperform the Rolands and they almost always beat Roland on price. The JV33 and CJV30 machines are from the generation before this latest version and they have held up very well. With the improvements on this latest version I would say they should last as long if not longer. You could get 10+ years out of this machine if you treat it right. The maintenance parts are easy to change and there are a ton of resources to learn how to use the machine to it's full potential.
One con is that switching between print and cut mode is slow and cumbersome. It is an automatic process but it get's annoying that it has to go through a relatively long initialization process between print and cut jobs every time. The Roland does this much faster but the print speed of the Mimaki makes up for that. Another thing that I don't like is there is a mechanism that puts tension on the material when you load it so that it goes in as straight as possible but it is flimsy and has a tendency to break or malfunction. It's a great idea but not engineered strong enough in my opinion. When it breaks you either have to take it off completely rendering it useless or try to fix it. The Mimaki only connects to your computer with a USB 2.0 connection which makes it harder to network if that is something you need out of the printer.
