Versaworks 6.15 File Corrupted issue
FCDsigns
I recently updated Roland Versaworks to 6.15.0 and now all imported files (except jpg) stop processing and say file is corrupted. I use Windows 7. Saw a post about changing user access in windows, done and did not solve. Anyone else have this problem? Is there way to get an older version without updating to latest?
Thanks for any help.
balstestrat
Problem Solver
Considering that Roland says that is the fix for the issue, I'm guessing you are doing something wrong settings the permissions.
White Haus
Not a Newbie
Have you tried closing VW and restarting it, or running as Administrator?
We've run into this with older versions and rebooting always fixes it.
FCDsigns
Yes, tried this, did not change issue. VW opens fine and can import JPG but nothing else. I am working to get older version of VW now.
[ dp_gz ]
same here - deleting files jobs @
Code:
C:\ProgramData\Roland DG VersaWorks\VersaWorks\Printers\VS-540i
nothing changes
have you tried *.tifs - for me that works
[ dp_gz ]
Code:
nothing changes
So - I fixed it yesterday!
Code:
Right click on the VersaWorks folder and select "Properties"
Click on the Security tab
Edit & make sure that "Full control" is checked for all users
Click Sharing tab then Advanced Sharing
Make sure the "Share this folder" box is checked
Click OK to close this window
