VersaWorks and Flexi contour cutting
ashleighfiddler
Hi all,
I print on a 64" Versa-art with Versaworks and do all my die-cutting through Flexi 8 on a Graphtec. If I want to die-cut anything I have to send the print through Flexi so that it will generate the cut job file for the graphtec.
my question is, is there any way out print through Versaworks and then be able to contour cut? I get better color consistancy when i send the print from versaworks, but lose the ability to contour cut.
Any help is greatly appreciated. Thank you!!
Versaworks will not sent data to the Graphtec.
There is a plug-in that comes with FC-series Graphtec plotters that would allow you to do this called Cutting Master 2.
