Versaworks and x rite i1 troubles
Discussion in 'RIP Software & Color Management' started by advisionsigns, Jun 21, 2011.
  1. advisionsigns
    advisionsigns New Member
    21
    I'm wondering if someone could tell me which device I should choose from the measurement devices tab in Versaworks 4. I have an X Rite I1 but the only options I'm getting are the Gretag Macbeth I1 and the X Rite I1IO. Those aren't exact matches and I cant get a successful scan with either one selected.
    I did the raise the scaling to 110% thing and Ive done a bunch of successful scans in the I1 profiler software so I'm confident in that ability. If I choose the X Rite I1IO I can scan C,M and Y but K gives me the 4087 error. If I pick the Gretag option I cant get a single successful scan.
    This is somewhat troubling but I'm sure it's just some simple thing I'm missing. So if anyone has some insight I would greatly appreciate it.
  2. eye4clr
    eye4clr Member
    310
    Once upon a time, long long ago, Gretag made the i1. Then the evil emperor X-Rite ate the kind and gentle Gretag; making the i1 its own!
    MUUUUUAAAAAAAAAAAAAAA
    Go with the gretag choice.
  3. advisionsigns
    21
    Thank you for the reply. Any clue as to why that choice does not work when I try it?
  4. advisionsigns
    21
    SOLVED!
    I goofed and forgot to set the color management to density control only. After I did that I used the Gretag I1 option and it worked like a charm :)
    Hopefully my flub will help someone in the future who googles this.
    edit: I recently attended the color management webinar from roland and asked about the device selections. He said the software came out before the merger but it was a good suggestion for them to update the choices.
  5. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    That error can also happen if you scan too fast, or on the wrong location. Sometimes, you think it should work, and you still get that error.
    Just rescan, and make sure you're scanning straight, and not too fast, and using a smooth steady motion.
  6. markw
    markw New Member
    1
    I have the same issue and still unresolved
    Just for the record i already tried the 110% i ve also plugged the spectrophotometer to a powered usb port the driver is working fine. turned off the windows defender and been doing the scans at different pace and speed but still without succesful results. Please help.
  7. SignMeUpGraphics
    SignMeUpGraphics Moderator
    1,354
    286
    83
    Apr 11, 2012
    Australia
    Deleted.
    Sorry, irrelevant post.
  8. DimOxy
    DimOxy New Member
    6
    Sep 6, 2016
    Las Vegas
    How do you set color management density control only?
    K gives me the 4087 error too... :(
