Versaworks contour cutting issue
landdesigns
I have noticed latley after doing my contour cuts on prints there are spots that are not cut. When opening the layout window I noticed the blue border around the print is close to the print eliminating parts of the contour cut (red dash border) showing the cut that will be made.
Is there a way to adjust distance of the blue border away from the print on Versacam so i dont have issues with the contour cut.
Check your blade
Check your cut strip for damage (replace)
See if the EPS Setting is not set to "0" - give it a .25 or so setting in your Edit (saves as default)
cfbeagle
Are you printing from EPS files? You need a larger boundary around the file.
I use Corel... In Corel when you export click on the "Advanced" tab, make sure the "bleed limit" box is checked, and put ".125" in the field beside it.
