VersaWorks contour cutting problem
SirSlarty
What would cause an unaligned contour cut?
I export an EPS of some text with a contour cut from Flexi and import into VersaWorks. There's marching ants red outline of the preview. I do a Print and Cut alignment setting. I laminate the print, line up the registration marks on the printer and the contour doesn't follow the outlines of the letters. It's off maybe a 1/16" on the x and y (axis).
threeputt
Possible things: Blade force set too high. Cutting speed too fast. Media shrunk due to cold temperature in room. Offset value is not at "0". Media is slipping under the friction rollers.
Just a few guesses.
SirSlarty
Oops, it's VersaCamm SP-300V
It doesn't align the crop marks properly. Print & Cut work fine but printing and aligning the crop marks throw the contour cut way off.
I called my supplier and they're looking into it. Sending them the samples and files that I used to see if it a software issue with Flexi.
javila
Tried doing the alignment for print cut, and the evironment match?
(assuming the sp-300v have those, I'm not sure =X)
Did you try printing and cutting a few very simple free forms ?? If not, try it and see how accurate they are and to which side they are off and if consistently.
SirSlarty
Gino, yeah I did, after every single print and cut it was off alignment exactly the same. I think something's up with the sensor eye.
