Versaworks Freezes/Quits
Discussion in 'RIP Software & Color Management' started by prosigner, May 25, 2013.
  1. prosigner
    prosigner Member
    92
    Dec 27, 2012
    Calgary
    Hey everyone,
    We are using the newest version of Versaworks and are having troubles with a few picky files, large files, but not over 500mb. They are from Wikipedia so I don't think they are corrupt.
    Is there anything I can do about this to address this issue?
    Thanks in advance,
    prosigner
  2. kanini
    kanini Member
    440
    22
    18
    Jul 13, 2012
    Finland
    As a workaround if it's just these files, could you save them in another format? E.g. If they are jpg you could try to save them as tif or eps or vice versa?
  3. rjssigns
    rjssigns Major Contributor
    5,164
    521
    113
    Jun 4, 2007
    Home Office
    I only send .eps or .pdf to VW. Large files also get sent between 10 and 25 percent of original size.
  4. Custom_Grafx
    Custom_Grafx Very Active Member
    1,637
    2
    Do they really need to be 500mb? How big are they? Tried JPG?
    VW will crash, with no or very poor log detail usually due to lack of system resources - sometimes not your fault either... Roland should probably make a 64 bit version sooner or later. Then again... on my newer system which had no shortages anywhere, VW never crashed, whereas my previous computer, which was only standardish, would crash at least every couple of days.
  5. DRamm76
    DRamm76 Member
    496
    1
  6. prosigner
    prosigner Member
    92
    Dec 27, 2012
    Calgary
    Thanks for the advice guys! :)
    So far changing the format is working. Yes, I do wish Roland would come out with a 64 bit Versa as our computer has more than enough power to handle this type of stuff. Thanks again fellas!
    Best,
    prosigner
