Versaworks IP
Discussion in 'Roland' started by MichaelAlmand, Mar 1, 2010.
  1. MichaelAlmand
    MichaelAlmand Member
    294
    Sep 27, 2008
    Canada
    Hi everyone, I am haveing troubles to get the IP adress hooked up for my printer I have tried everything How do I do it? any help would be great
    Thanks Mike
  2. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    Do you have the "Net Tool" software installed as well? You need to have this installed first to assign the IP address.
  3. OADesign
    OADesign Active Member
    794
    53
    28
    Jan 27, 2006
    California
    Knowing what machine you have might help.
    I am assuming that you have the Version of VersaWorks that came with your machine (not purchased aftermarket with the hardwarelock).
    If its one of the older machines sc540 sc545 sp versacamm series (sorry the model numbers escape me), then Mike is right. The print server net tool will allow you to assign an IP address to the machine.
    http://support.rolanddga.com/docs/D...rvices/Downloads/print_server_nettool_1.8.exe
    If you have one of the newer manchines xc vp v series.
    Then you have to set the IP address internally in the machine.
    From the menu select SYSTEM INFO > NETWORK > IP ADDRESS.
    details instructions can be found in your manual.
  4. MachServTech
    MachServTech Very Active Member
    1,236
    7
    38
    Sep 19, 2008
    North Carolina
    Look for your Net Tool CD
  5. rolanddrivesmecrazy
    rolanddrivesmecrazy Member
    35
    are you running a server at the place where the system is installed you can identify devices through the server i've treid net tool pain in the arse for some reason i did manually
