VersaWorks Weirdness
TheMattMan
I have a problem with a piece of art that I have scanned and set up in Corelx3 that is not opening in VersaWorks. I have exported it out as a .eps. If it is 12"x12" or smaller it exports out and opens in VersaWorks no problem. When it gets any larger than this it tells me in VersaWorks that the file is corrupt after loading to about 80%. Same file, same type of file, the only difference is size. Is this something I am doing or a weird program glitch?
Thanks much,
Matt
HardbargerSigns
What size does your final print need to be? I've seen this before, but mostly with larger, Photoshop files.
If you can get the image into Vworks at about 20"X20" it should print just fine. You may also try reloading Vworks, to get rid of the bad information.
There are many things could be your problem here. First…. are your numbers 12 inches by 12 foot or inches ?? I can’t tell from your post.
If its 12 feet, proportionately downsize it so VersaWorks can read, rip and print it and let the software re-size it up for you.
I think Corel is doing some hocus-pocus crap and VersaWorks can’t translate it.
TheMattMan
I ended up exporting the banner out half size and resizing it inside versaworks and it worked. The banner was a 2' x 12' and the image only took up maybe a 20" x 20" area, and it would not open in VersaWorks.. I belive the file size was just under 200mb. I exported the banner out at a 1' x 6' and it did it no problem. (File size ended up being under 100mb) I've loaded way larger files than this before with no problems.. Would this be a processing problem or maybe just a hangup between the programs.
TheMattMan
I had another job do it today that was very large.. so I tried the same method of reducing this 4'x8' banner down until it was around a 18" x 3'... it still said file was corrupt.. So I opened the so called corrupt file with Illustrator.. no problem.. exported a .eps of the same file and it opened in VersaWorks no problem. Now I don't know what to do.. I tried changing settings while exporting a .eps and it didn't make a difference. Any Clues?
Rudy
If you're not contour cutting, why not export as a tif.?
Works great every time and loads fast.
TheMattMan
I am using Version 2.1.0
I don't care much for .tif files... and I have my colors worked out with .eps and know what I am going to get when I export.
Doyle
I've had that happen to me once or twice, and I usually just go back to the file in your graphics program and re-export it.
Kenny
Are you opening the file local, or on a network? I sometimes have to copy problematic files to a temp file on the PC running Versaworks (have seperate design/rep PCs).
TheMattMan
I've had it happen a few times and usually re-export with no problems also.. but not now.... these files are on the same computer as versaworks. I tried rescanning the art with a different scanner (recently upgraded scanner) thinking this was the problem, but it does the same thing. It's making my Head Hurt.. lol
