VersaWorks-won't let me tile horizontally?
bayviewsignworks
I have a graphic that I need to print horizontally in order to get two tiles. As soon as I click ok, it sets it back to vertical?
Andy
cajun312
Try rotating your image 90 degrees in your graphics software. Sometimes you can reduce the size of the graphic in versaworks till it fits within your page width, then rotate 90 degress, then return to 100% size.
bayviewsignworks
After I reduced it, then tiled it, it then wouldn't let me size it back up to 100 percent. As is was I need to do three panels instead of two. Thanks though, nice work-around.
Andy
Sign Works
In Versaworks go to "Clip & Tile" then select "Number of Tiles" then increase to desired "Number of Vertical Tiles"
I know sounds crazy but tell me this dosen't do exactly what your trying to achieve.
