VG2-540 Orange Corel Palette?
Farmboy
So far very happy with this printer. For anyone that's using this with Corel, have you had any luck finding the Orange files to add to Corel's color palette? Illustrator seems to be the only one up to date in versaworks.
unclebun
Are you talking about the spot color library in Versaworks? I found these instructions for CorelDraw.
When using CorelDRAW 11, 12, or X3
  1. Open the folder [C:\Program Files\Roland VersaWorks\Swatch\CorelDRAW] in the RIP server (computer with VersaWorks installed).
  2. Copy the [userinks.cpl] file.
    If the target computer is different from the RIP Server, use a network or an external storage media (such as a USB drive or floppy disk) to copy the file.
  3. Launch CorelDRAW on the target computer.
  4. In the CorelDRAW menu, click [Tools] - [Palette Editor].
    The Palette Editor dialog box appears.
  5. Click the [Add Color] icon.
    The [Select Color] dialog box appears.
  6. Select the [Palettes] tab.
  7. Select [Custom Spot Colors] from the [Palette] drop down list.
  8. Click the icon (File Open) next to the drop down list.
  9. Select the file [userinks.cpl] copied in step 2 and click [Open].
  10. Select the colors from the list that you want to add to [Custom Spot Colors] and click the [Add to Palette] button.
  11. Click [Close] to close the [Select Color] dialog box.
  12. Click [OK] to close the [Palette Editor] dialog box.
  13. Delete the [userinks.cpl] file you copied in step 2.
  14. Relaunch CorelDraw.
