JACsigns
Hi,
First time running reflective on the machine, had to set up the media manually as it couldn't do it by itself. Printed the image and laminated then put it back in to cut. NOPE, it wasn't doing it. finds the first crop mark but wouldn't find the second one. said to do a Multi sensor adjustment. Manual says to tap the 3 lines(menu) tap Media setting> other media settings> multi sensor adjustment. Well I'm stumped.. there isn't a "Media Settings" once you hit the 3 lines... anyone have any ideas? or am I doing something wrong?
When I put the media back in to cut I line the first mark with the little hole in the clamp like my tech told me... not under the hole, equal to it. base point and hit send in Versa works. finds the first one, the long bar , moves to the second and doesn't find it.
