Need Help Viewing saved files on signlab
Discussion in 'Signlab' started by undertaker, Sep 24, 2019.
  1. undertaker
    undertaker New Member
    12
    Sep 23, 2019
    ireland
    Hello everybody, I am a stonemason based in Ireland.
    I recently switched to signlab 10 as the package I use for designing and cutting stencils, I use a Summa plotter.
    This software is much more complex than the previous system I used and has many features I really don't need.
    I regularly run into problems and I have joined this forum in the hope that more experienced users might have time to help me occasionally.
    The current issue is this, when I design a stencil I save it using the save as button which works fine, if I need to open this file again to check something it's right there,but her is my problem, if I need to open 2 customer files and have them both on screen I can't, the first one disappears when I open the second, is there A way I can gave two files open on screen at the same time.
    Thanks for taking the time to read this.
  2. gabagoo
    gabagoo Major Contributor
    5,724
    105
    63
    Oct 10, 2006
    Vaughan, Ontario
    You have to open the first file, then import the second.
    • Agree Agree x 2
    • Like Like x 1
  3. jimdtg
    jimdtg Member
    284
    23
    18
    Jun 18, 2017
    Some places in earth
    May you switch window to view?
    • Like Like x 1
  4. tbullo
    tbullo Superunknown
    391
    44
    28
    Apr 5, 2012
    VA
    Just use import to open multiple files.
    • Agree Agree x 1
  5. d fleming
    d fleming Very Active Member
    2,772
    229
    63
    Nov 28, 2007
    Middleburg, Florida
    I have a two monitor setup.Using multiple instance under options you can have more than one file open at a time. Place one open file on each monitor. You can drag/drop between them, or import as others have stated.
    • Like Like x 1
  6. JR's
    JR's Very Active Member
    2,904
    105
    63
    Sep 6, 2007
    swansea Ma 02777
    Mr. Fleming, you just taught me something mind blowing.
    I have sign lab 64 bit and 32-bit and they both do certain things good.
    I would constantly save file and reopen it in the other program
    I did not know I can drag-and-drop. So cool thank you
  7. undertaker
    12
    Sep 23, 2019
    ireland
    Thanks a million folks,I did not know about importing a second file,
    this is such a help to me, I really appreciate it.
