Vinyl Curling at edges
Discussion in 'Vehicle Graphics' started by Signature Sign Guys, Sep 28, 2018.
  1. Signature Sign Guys
    Signature Sign Guys Member
    62
    2
    8
    Apr 11, 2018
    Kamloops BC
    Hey Guys,
    I have been having quite a bit of jobs lately come back with the edges curling up. We clean every job with iso and we are using 3M IJ35c with a drytac uv laminate. I am wondering if this combo is just not compatible but our supplier has said that it should be fine. Does anyone have any insight on what I need to do?
  2. BigfishDM
    BigfishDM Merchant Member
    5,056
    428
    83
    Jun 22, 2009
    All Over
    What type of ink are you using? Did you cut right to the edge of the graphic?
  3. BigfishDM
    5,056
    428
    83
    Jun 22, 2009
    All Over
    3M Edge Seal is another way to keep your edges down. It's a little more work but it really helps with issues like this.
  4. Pixels Are Bad Mmmkay?
    Pixels Are Bad Mmmkay? Very Active Member
    Why not just use the recommended 3M laminate?
    • Agree Agree x 1
  5. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    What about dirty hands contaminating the edge of the vinyl?
  6. Signature Sign Guys
    62
    2
    8
    Apr 11, 2018
    Kamloops BC
    ecosolvent and yes. I do use edge tape on some jobs but these were simple decals and did not need the reinforcement.
  7. Signature Sign Guys
    62
    2
    8
    Apr 11, 2018
    Kamloops BC
    i try very hard not to touch the edges when installing. If I do I reach in about an inch or so
  8. BigfishDM
    5,056
    428
    83
    Jun 22, 2009
    All Over
    I suspect the prints were not completely out gassed. Cutting to the edge with eco-solvent inks before its fully outgassed will do that everytime.
    • Agree Agree x 1
  9. Signature Sign Guys
    62
    2
    8
    Apr 11, 2018
    Kamloops BC
    This happened within a week of the install and we also let the prints out gas for at least 24hrs. I am wondering if the lam is just not compatible with the vinyl and is shrinking faster than normal or a bad batch of lam.
  10. iPrintStuff
    iPrintStuff Prints stuff
    1,044
    293
    83
    Sep 3, 2018
    United Kingdom
    Where are you putting these vinyls? Ours only ever curl up if the laminator is too tight
  11. Signature Sign Guys
    62
    2
    8
    Apr 11, 2018
    Kamloops BC
    Vehicle Windows, and doors. and our laminator uses the weight of the roller to lam
  12. tooler82
    tooler82 Member
    78
    13
    8
    Sep 5, 2013
    Camp Shelby, MS, USA
    I use 8509 or 8508 laminate with my ij35c. Never had a problem yet. Get you a roll and try it to see if that fixes it.
    • Agree Agree x 2
  13. AKwrapguy
    AKwrapguy Active Member
    969
    281
    63
    Sep 6, 2014
    Anchorage, AK
    I think the issue is the material. If I'm not mistaken isn't IJ35 calandered. I would look at using a cast material. Not sure about the lam as well.
    • Like Like x 1
    • Agree Agree x 1
  14. tooler82
    tooler82 Member
    78
    13
    8
    Sep 5, 2013
    Yes it’s calendered. Recommened Graphic Protection: 8508, 8509, 8510M, 8048G, 8050M
  15. Jester1167
    Jester1167 Premium Subscriber
    Just because the reps push calendared material and it says it last 5 years doesn't mean it is the appropriate material for the job. This has always been a pet pev of mine and years ago a friend and I did the research on cast versus calendared cut vinyl graphics. When we did the math you saved on average $5 by using calendared over cast on two truck doors that were 1' x 2' with a two color graphic. It's not worth the aggravation, your reputation, and the time and trouble to redo the job because the edges shrunk and left the dirt adhesive rings, the inside corners of the letters cracked, and or the edges curled up...
    If you take the time to analyze the costs involved you will find the the cost of materials are one of the smaller factors in the cost of good. Your time is better spent on maximizing and streamlining production. Labor is your largest expense.
    Calendared material is for short term temporary jobs period. Just look at the odd color of vinyl you have left from years ago and compare cast versus calendared shrinkage on the roll...
    • Agree Agree x 2
  16. ikarasu
    ikarasu Very Active Member
    1,944
    618
    113
    Jun 10, 2016
    Port Coquitlam, bc
    Move up to IJ40 / 8508 and you'll be fine. IJ35 is the cheap crap thats meant for temp stuff... IJ40 worksa great for even vehicle decals. Anything that needs to stay flat.
  17. BALLPARK
    BALLPARK Member
    488
    42
    28
    Dec 5, 2008
    Radford, VA
    We only use Cast on vehicles after having issues with the top brand's calendared vinyl on vehicles. I've used a lot of the IJ35 in the past and it's only used in our shop when the client has no funds or it's a short term project outdoors with the sign being tossed after the event.
    • Agree Agree x 1
  18. Kentucky Wraps
    Kentucky Wraps Kentucky Wraps
    1,176
    58
    48
    Mar 6, 2009
    Bluegrass
    How long is it before they come back to you? A year...a month...a week?
    You void any kind of solution from BOTH material manufacturers if you use non-compatible materials (ie. 2 different brands).
    3M IJ 35 is a PERMANENT adhesive.
    Not sure why you or your supplier thought either of those products were the right material for the job, but you are both extremely mistaken.
