Vinyl Cutter[ing] Problem HELP !
Replicator
For the past week or so I've been getting some lines cutting like they are perf cuts (ODD) . . .
Roland GX-24 is the cutter and we have replaced the cutting protection strip, blade holder and blade in an attempt to correct this issue.
Does anyone have a clue what this might be, or has anyone had this problem and resolved it ?
Thanks for reading !
joeshaul
Looks pretty interesting.
Since it looks like it does it only in one direction, I would guess it's some sort of sensor malfunction. Never owned a GX24, but if it has a left and a right sensor, the right one may be dirty/faulty. If the encoder bar was whacked, you'd get the same for the right to left motion, but this looks like it's isolated to left to right motions only (assuming the blade starts at the upper right, cuts left, down, right, then up).
Just out of curiosity, what does it sound like when it's moving in that direction? IE: Does it sound like it's pulling the blade up, moving, putting it down intentionally, or does it make any kind of stutters or groans?
Air Art Girl
it does make a low pitched noise when it moved in that direction. It makes it in the direction when the vinyl rolls forward and it is cutting.
Replicator
Got it figured out . . . Believe it or not it was as simple as removing a 60° blade and putting the 45° blade back in the blade holder !
This cutter almost ONLY cuts thermo-flex vinyl, not standard vinyl and apparently the vinyl just doesn't like 60° blades . . .
:doh:
Check the old blade...it may have a "chunk" broken from the tip area...this is common, it doesn't take much of a piece missing to make the blade chatter across the vinyl.
