Tony Rome
OK I have a question.
I posted earlier about outsourcing cut vinyl.
One of the reasons was it was a big job I did not have time to weed, the other reason is my cutter (I use my Roland SP 540V) does not cut detailed enough.
I got quotes from 2 different place one sent me back a proof that was not very accurate, as they made most angles cuts into curves for easier weeding (this is a legitimate big company).
I sent them to another place and they sent me a proof that was perfect, razor sharp angles.
So, they must be using two different machines, right?
So I thought baout it and was wondering, maybe if I had a better cutter I would have done this job, but even with adjustments in material, blades, pressure, I could not get this (detailed) logo to be able to weed well.
In other words I need to be able to pull the initial layer off without it pulling up the smaller pieces, I was having to hold them down one by on eas I pulled.
So, I know the 540 is not a "great" cutter, but are there cutters that will cut more intricately?
