Screw brand names.. learn to tell what kinda of vinyl your buying..
Most vinyls are a form of PVC (Polyvinyl Chloride) they just add things to it but it's still mainly PVC..
When you see Calendered or Cast that has to do with the way that vinyl is manufactured. Calendered is a lower grade and Cast is the higher longer lasting.
Each one can come with a different adhesive which again can change the application/ues of the vinyl.
If I were you I'd look at where it's going and how long it's supposed to be there. That will tell you what type of vinyl and what type of adhesive your supposed to use.
Doesn't really matter who makes it..
What I can tell you is find a mid range vinyl and a high range vinly and stick with those. Don't cheap out because your only going to loose $$ and you really don't save anything by trying to go cheap.
We could get into the whole thing about printing on the different vinyl but that would make my head hurt!
