Vinyl Express 7.5
Discussion in 'General Software' started by signD, Mar 14, 2009.
  1. signD
    signD Member
    29
    Oct 31, 2006
    Nebraska
    I'm using VE 7.5 and have created a logo. I've used several different pieces to create the logo and would now like to eliminate the cut lines that cross over other parts of the logo. I somehow need to convert all these pieces to one so that I can cut. Can anybody help me with this? THANKS!
  2. Rodi
    Rodi Very Active Member
    1,333
    1
    38
    Aug 3, 2007
    Not having used the software, but there should be some welding feature that will give you all the options you need. Even my old Cocut 9 Pro gives me welding by all colors or individually.
  3. blackicefx
    blackicefx Active Member
    629
    Effects>Combine>Weld
    I'm also running a version of VE Master+ 7.5 on one of my machines.
    Matthew
    BlackIceFX
  4. RebeckaR
    RebeckaR Active Member
    756
    3
    18
    Mar 7, 2008
    utah
    You don't specify whether you are using Apprentice or Pro. VE Master Apprentice probably doesn't offer you the welding option. VE Master+ does.
    It's been a long time since I used it, so I don't really recall, but Production Manager may offer you the option to auto-weld. Take a look there.
  5. signD
    signD Member
    29
    Oct 31, 2006
    Nebraska
    Another question on Weld - after I have welded something is there a way to separate it again if I need to make edits?
