Click to Support Signs101 ...
Ok so a tint buddy of mines is having a issue with it dulling blades super fast, 30 degree and cuts only tint, new teflon strip, and after a few patterns its dull? any thoughts? thanks in advance
You only need the slighest pressure to cut.
When you use too much pressure (too deep) the blade is binding through the cut and wears out the cutting tip surface of the blade and then it wont track accuratly.
Does that make sense?
After Market Blades Are Junk!
