Vinyl for textured wall
paul luszcz
What vinyl would you use to adhere to the textured wall shown in the photo attached?
I have to print two spot colors and would ideally do so using my Gerber Edge, so 15" vinyl would be preferred.
I outsource all my inkjet and flatbed printing and don't expect my printers to stock such a specialty item.
C
ColoPrinthead
Guest
Avery 2611 has worked well for me in the past. I have used 3M IJ40 on similar walls but feel it didn't take the texture as well. Both removed clean and easily after more than a year, both images were full bleed and the 3M lifted more on the edges.
mattcook8150
Phototex
J Hill is correct...2611 is the incorrect option here. Use Phototex opaque or Phototex Extra Strength...Phototex Opaque's adhesive has 20% more grip than the regular Phototex product...extra strength is even more than that, but will potentially take off the paint. Is this a low VOC paint of any kind?
Marlene
3M 180C controltac might work as it's made not to trap air and conform to shapes like rivets and such. it comes 15" punched
eahicks
+1
SignManiac
Although I really like the Phototex, I have some areas in my man cave where it has let loose and that was using the more aggressive adhesive. Just a consideration.
Also wondering if I put some heat to it, will that reactivate the adhesive?
