Vinyl for windows
Discussion in 'Materials' started by msenjur, Feb 3, 2010.
  1. msenjur
    msenjur Member
    327
    4
    18
    May 21, 2008
    Slovenia
    This guy is asking, where he could get these kind of decals? Vinyl should be able to stick in the back of the window. So, print must be on the same side.
    I heard, that solvent printer cant do this kind of print. What printer can? And how does it do it?
  2. CoryP
    CoryP Member
    33
    I have printed on static cling on the face side and stuck it on the inside of the window. It goes on good, the only window I have put it on was really thick glass, and when you look at it, the white got a little dull, but I was still pretty happy how well it went on.
  3. strypguy
    strypguy Active Member
    675
    37
    28
    Jan 18, 2009
    Carroll, Iowa
    You can reverse print on clear and laminate that with a white vinyl for background.
    John
  4. msenjur
    msenjur Member
    327
    4
    18
    May 21, 2008
    Slovenia
    yes, i was also thinking in that direction. But im affraid, that color arent gonna be so full...
    But some firm does this without white vinyl. I heard, that printer is ink-jet, but how do they get the adhesive on same side as print? Do they do it manualy?
    I thougt someone has done it before...
    Cory; yes, but your version is vulnerable... if it is behind glass, it is fully protected!
  5. DGDesigns
    DGDesigns Member
    96
    To my knowledge it's not about the printer, but rather the right material. Quality Media has what you're asking about. Check out http://www.qmls.com/www/window.htm and talk to a rep. You can print on a specific window material and use a double-sided adhesive layer over top so the graphics can be viewed from the same side as the adhesive layer. Hope that helps.
    Also, you can order custom decals like this from Stouse www.stouse.com
  6. Mike Paul
    Mike Paul Major Contributor
    5,438
    8
    38
    Dec 30, 2003
    NJ
    It's quite common to thermal transfer print reversed CMYK on clear with a White finisher on a Gerber Edge or Summa.
    As for a solvent printer, you would need to outsource to someone who can print White ink or laminate with White vinyl.
  7. msenjur
    msenjur Member
    327
    4
    18
    May 21, 2008
    Slovenia
    laminate with white vinyl - that we can do by our selfes...
  8. msenjur
    msenjur Member
    327
    4
    18
    May 21, 2008
    Slovenia
    yesterday i went to this studio, that is also offering these kind of prints. But the guy there said, that they are printing on solvent printer, in have a special machine, that add adhesive beetwen print and glass. So, that there is only one layer. When i took a look at samples, colors were realy life! very nice prints!
    Today we will do the print on clear vinyl, and then overlaminate it with white...
    Some other guy, that is selling materials, said, that adhesive may become a little bit yellow over time... what about that?
