vinyl material
graphix
What are some of the choices for just car decals, i use 3651 and 3165 but when contoured on a full bleed and letting it dry the edges always curl up..any suggestions on what is going on and i would like to try different brands as well, Thanks roland 540
asd
if you are cutting without laminating, it doen't matter what brand of vinyl you use it will always curl up, BUT if you cut the vinyl where there is no ink
the vinyl will cut fine, if you can get away wtih leaving 1/16" outline around your graphics thats the best way to avoid the curl up issue
401Graphics
This!
Also 3640 is lower cost vinyl.
