Vinyl numbering system
Discussion in 'Newbie Forum' started by bigzap, Sep 22, 2008.
  1. bigzap
    bigzap New Member
    2
    Hello...........
    I've been searching and searching the forums here and haven't found an answer to the following question.
    What does, for example, the number 651 represent when you purchase rolls of vinyl?
    Could someone enlighten me, (an obvious newbie)??
    Thanks a lot!
    Les
  2. signage
    signage Major Contributor
    9,518
    75
    48
    Oct 5, 2005
    Penn
    These numbers are different grades of vinyl from each manufacturer. You need to contact your deal and get color chart that will tell you some of the info about each series!
  3. Aardy54@54-Design
    Aardy54@54-Design Member
    85
    Mar 3, 2007
    I like to analogize so ....
    Let's take BMW for example, there was the 318, 325, 525, etc... each number within the BMW product line represented a different model - same with say Oracal: 851, 751, 651 in that they are their different products and use numbers to represent the model instaed of calling 851 Superior Cast & 751 Premium Cast ... the numbers are the name they assign the different products.
