VinylExpress Q54 HELP
Discussion in 'Miscellaneous Plotters' started by Kelsey Adams, Apr 15, 2019.
  1. Kelsey Adams
    Kelsey Adams Member
    66
    Jan 13, 2019
    Pennsylvania
    I struggle to line the registration marks up straight so I am constantly having to adjust the vinyl until I get it as close as possible. What can I do to help placing the vinyl straight into the cutter and not having to mess with it. It is very time consuming and irritating. I use the Graphtec 4 point registration marks, FlexiSign to print and cut. Thanks!
  2. bannertime
    bannertime Very Active Member
    2,160
    505
    113
    Sep 8, 2016
    No
    It doesn't have to be perfect, that's what the marks are for.
    For sheets, I bring the sheet half way through. Line up the edge on the edge guides. Run it as a sheet.
    For rolls, I'll pull material through, reach around and hold the roll tight and pull the media tight. Typically will line up pretty straight. Or just like up the edge with the edge guards.
Similar Threads - VinylExpress Q54 HELP
  1. Joseph Siddall
    5
    1,394
