Vinylmaster Letter 4
BaBaboey31
I'm new to VM, used Flexi in the past. I want to edit nodes but can't figure out how to. See the attached file. I want to round the pointed front upper part of the #3 so it will match the outline.
Can I not edit nodes in letter version?
Gary
S'N'S
Select object (no 4)....Look at top and go across to "CURVES" then in the drop down "Convert to curves", change view to wire frame, then select your node editor (on left side, black arrown with squiggly line)and change whatever you want.
It would be easiest to change the letter to how you want and then Outline it.
Can't see any attached file...:covereyes:
BaBaboey31
FYI, I did change shapes then add the outline, but the outline was making a long weird section on one point. That's why I wanted to try and change it. Thank you very much for the help!
