VP-540 8 ft print is 8' 3/4"
stickamain
I thought I'd be slick and do multiple prints that fit a 4'x8' sheet. Mount and then cut apart. "Piece of cake", I thought. problem is, the prints are coming out about 3/4" to long. What is causing this? There is a hint of banding like maybe it's advancing just a hair to far on each pass. Is it something I'm doing wrong or can this be adjusted in settings? Any help/tips would be appreciated.
shoresigns
Also known as "feed calibration", at least on my Roland. If I understand correctly, you want to turn it down​ by 0.8%. That's quite a large correction though, so just to be sure I would do a calibration test.
stickamain
Thanks. Did a lil bit of lookin, and I'll bet a shiny new nickel you're exactly right. Thanks again, one day maybe I'll be good at this stuff.
