vp-540 ink
Discussion in 'Roland' started by signrios, Dec 20, 2008.
  1. signrios
    signrios Active Member
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    quick question, i'm cleaning my vp before heading on vacation,(leaving monday) i'm done cleaning it and did a test print when the out of ink message came out, looks like i'm out of magneta!! and don't have any around.
    i checked the display panel and it shows 1 line.
    my question is will it hurt the machine not having a full ink cartridge when doing the periodic self-cleanings?
    i've some cleaning liquid cartridges, will it do more damage than good if i insert one into the magneta slot?
    thanks
  2. CS-SignSupply
    CS-SignSupply Very Active Member
    Based on other brand experiences, I would recommend inserting the Cleaning cart so the line has no air in it to possibly dry up at all.
    Cleaning fluid will not damage anything.
    Just a suggestion.
  3. signrios
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    so i would just insert the cleaning fluid and then replace it with a new one once i get it?
    any flushing has to be performed afterwards?
    thanks
  4. CS-SignSupply
    I would recommend inserting cleaning cart and letting it go.
    Once you get back, replace the cleaning cart with new ink cart and run a few cleans to pull the cleaning fluid out.
    Will waste a bit of ink but may be the safer approach
  5. signrios
    699
    3
    18
    Feb 26, 2007
    Rio Grande Valley
    thanks cibersupply,
    i think this is what i'm gonna do.
    i guess after getting new ink i can buy a serenge and bleed just the magneta line, is this possible?
  6. CS-SignSupply
    Sure it is... and a good idea to save you the ink.
