VP-540i Clear at one end fuzzy at the other ??
Biggermens
Hi There
Would any one know why my vp540i is printing clear on the right ( control side ) and printing fuzzy on the left side ??
The machine is level and solid, i have also made sure the encoder strip is clean too still same thing
Biggs
Biggermens
Here is zoomed in picture
Gabil
Gary
Check media flanges and left pinch rollers. Check feed motor hours, run feed motor aging test. Clean grit encoder.
Biggermens
I will double check all that, I rebuilt this machine, it is pretty much new from one end to the other
would the vacuum affect that ??
I do the checks and it is pulling hard, until you start to print then pretty much nothing
I checked all the settings in versa works and its all set to strong
Biggermens
do 'Linear encoder'
then 'Linear chack'
then 'Linear calib',
then the limit initialization.
I will do all that, i am a bit more concerned about that vacuum.
I set it from Auto to 100% and it running 100% all the time but when its printing
cutting vacuum its running at 100% every other time its running 100% just not when its printing
set to strong in versaworks
The print cut is bang on, I did about 1000 decals since this morning and no problem with print cut
henryp
The carriage might not be parallel to the platen, I have seen this on other printers where in the gap between the pint head and the platen is not the same between the left and the right side of the unit.
Biggermens
You are probably right, not sure why it would be off, it was printing fine last week and i did nothing to it
player
Can you try it in the slowest mode where it only prints on the way up ( I forget what it is called). Maybe it's an ink/damper issue.
GTSTech_1
If printing in Uni-Direction fixed, then you need to look at the head alignments. Set the base point at he problem side and perform the alignments. Would also double check the carriage height right vs leftside. I once had a customer that for whatever reason would move his printer to different locations using a forklift and ended up bowing the printer frame, but with him the print was good only in the middle, edges were less quality.
Just my .02
henryp
Looks like that fixed it, but that takes double the time :(
must be encoder stripe ???
The gap between the print head and platen is most likely not uniform across the width of the printer. You will never obtain good prints when printing Bi-Directional if that gap is not constant because the time it takes for the ink droplet to hit the media is different between the right side and the left side of your printer.
Have a look at the attached file so you can see what I am talking about.
  • DropMaster_small.pdf
Biggermens
You are right, what i don't get is the machine never moved, i put a dial on it and looks like its about 0.030 off
do you know what the tolerances are ???
henryp
Sorry, I only work Mutoh printers so I would not know the tolerances for a Roland printer. I suppose you need to find a way to make the gap equal to the side that prints OK.
