hello I was wondering if there's a solution for my problem. Lets say we have media 1000 cm width, in Corel I've made a circle -120 cm width with cut contour and photo inside. I put it to versa, get width media from machine and a part of my circle is cutted and put lower. It's normal but cutcontour is not closed anymore. It means that it cuts only a part of circle, just to the edge of winyl, then this straitght edge isn't cut.How to made VP540 to cut everything? One semi solution is to chec -cut all boundaries. With that this straight lines are cut but sometimes it still doesn't close the curve... I hopr it was a liittle bit understable
regards
Anax
regards
Anax
