Vs-540
Discussion in 'Roland' started by ScottyAdams, May 25, 2012.
  1. ScottyAdams
    ScottyAdams Member
    186
    Hey guys,
    Im new so bare with me...We just got our printer in last week. So I'm just starting to play with different materials and profiles. Im printing on a 13 0z glossy banner material. When the print comes out the ink is very "dotty" (if you can understand what I mean). I am not getting a consistant printed color. What could be the cause of this and how can rectify the issue. I want to get the issue figured out before printing at full scale size. Thanks guys! I really appreciate the help.
  2. Wiggum PI
    Wiggum PI Member
    298
    Oct 3, 2011
    Melbourne Australia
    Maybe up your heat settings to close to max to start, or it might just be the top layer of material,try pulling a bit more through.
  3. tomence
    tomence Very Active Member
    1,647
    25
    48
    Feb 10, 2009
    IL
    What profile on what material and what temperature.
  4. ScottyAdams
    ScottyAdams Member
    186
    Im using a generic banner profile that came with versaworks and the material is emerald gloss banner 13 oz. Ive tried a few different profiles and all have this effect. Heat is set at max 112
  5. ScottyAdams
    ScottyAdams Member
    186
    dryer is at 122 btw
  6. Pacific Coast Sign
    Pacific Coast Sign Active Member
    548
    1
    18
    Jun 19, 2008
    Portland, OR
    Go to the manufacturers web page and see if they have profiles for the media you are using. It sounds like a profile issue to me. If they don't have a profile then you may be able to use one from another manufacturer like Oracal.
  7. Mainframe
    Mainframe Very Active Member
    Set your heat to 90, dryer to 94, try that, also try gcv profile and also sign and display.
    Worth a shot
  8. P Wagner
    P Wagner Very Active Member
    1,914
    80
    48
    Aug 16, 2006
    San Diego
    There can be many causes of 'dotty' or speckled solids. In addition to the things already mentioned (temperature settings), these can include:
    Bidirectional alignment - this should have been performed by the installer of the printer. You can run a user-level bidi calibration as well (check your Roland user manual for instructions for this).
    Head height - high setting will likely show more speckling in solids.
    Head speed - slowing down the carriage speed while printing can reduce the appearance of spotty solid colors by improving drop accuracy.
    iCC profile - if the speckling is more visible in brighter colors (highlights), the ICC profile may be using more K dots than it should, resulting in speckled highlight colors. If you have the tools to build profiles you can create your own ICC profile so to improve this.
    The other option here is to try other media profiled from various sources like manufacturers of media, or distributors, or any other sources thar you can find, and then test.
    In general, scrim banner medias tend to hide print artifacts more than most other medias do, so if you are having problems with banner media, you may also have similar issues with other media types too. Hopefully you get this sorted out. Good luck.
  9. I know this may sound stupid, but the first time I ran banner through my first Roland printer, I had similar results.
    I found it to be that I had put the roll of banner on the printer the wrong way round so it was in fact printing on the back of the material.
    All the banner material I have used has the printable side on the inside of the roll, not the outside in the way digital vinyl does.
    I know this is a long shot, but I had a similar problem when I got my first machine.
    Neil
  10. Fatboy
    Fatboy Very Active Member
    +1
  11. scuba_steve2699
    scuba_steve2699 Member
    287
    Did the same thing first time I printed canvas!
  12. WCSign
    WCSign Member
    358
    1
    18
    Mar 12, 2012
    Bay Area
    mine did the same thing.. did you ever get it figured out?
    I had to get a custom profile made, turn heat down
  13. 2B
    2B Very Active Member
    3,037
    393
    83
    May 5, 2011
    TX
    what program was it designed in? was the design done in RGB or CMYK?
    Temps are too high,
