Elle@Signa
I am hoping someone can help.
I have created a design on Canva, downloaded it as a PNG and opened it in Illustrator. I have then done an Image Trace to change it to an object and added the Roland Cut Contour. I've then saved it as a .eps
When I load the .eps into Roland and choose Cut Only, it is cutting in a random sequence. This means the vinyl is going in and out constantly. For example, today it spit out 3metres of vinyl to cut 1 letter and then pulled the full 3 metres back in to cut another letter at the other end. Irt just kept doing that.
Does anyone know if there is a way to get it to cut in order instead of it randomly going up & down and left & right?
