VS640 when tiling an image the cut lines shift over
Clive
Hi
VS640 when tiling an image the cut lines shift over, but they dont shift in equal amounts, if i have 2 parts of the image on the printer say 50 cm wide x 240 long, when it has finished cutting the left hand print will be over by say 1.5 mm and the right hand print will be over by 3-4mm
i have even tried to correct this with crop marks
i have tested with a smaller area and the cut is fine
can anyone help with this issue
