Wall Covering Material Vinyl PS
Discussion in 'Digital Printing' started by normanmacleod, Feb 18, 2010.
  1. normanmacleod
    normanmacleod New Member
    5
    What does everyone use for an interior wall mural?
    I was going to use standard calendered w/lam but am concerned about shrinkage over time.
    Wall size is 8' high and 30 feet long. It is not a temporary graphic but may need to be removed someday.
    Do you usually laminate it?
    Using Roland with ecosol inks.
  2. ZsVinylInc
    ZsVinylInc Member
    310
    Have you thought about PhotoTex?
  3. normanmacleod
    5
    Hi Zs;
    I am going to order a sample of Phototex today and test it.
    My biggest concern is that the client will be leaving this up for years and there will be at least 4 vertical seams down the wall. I am worried that a product that removes easily may also start to curl back and peel on its own over time.
    Has anyone used this long term with good results? How do the seams line up? and how much overlap do you give them?
  4. WB
    WB Active Member
    843
    2
    18
    Feb 9, 2006
    Canada
    What about the Oracal removeable wall vinyl?
  5. MachServTech
    MachServTech Very Active Member
    1,238
    10
    38
    Sep 19, 2008
    North Carolina
    Has anyone tried PhotoTex or other wall material for the HP Latex? Just wondering if it can handle that material.
