Opinion Wall Substrate cutter, Recommendations?
edsteve
I'm about to pull the trigger for a wall substrate cutter. I'm considering a Fletcher fcs and a SSC 165A.
Need to cut ACM at least 4mm, foamcore, gaterboard, sintra 4mm and 6mm if possible, aluminum is also a plus. Is there any other suggestions besides the two above? Any and all comments are appreciated. Thanks-Ed
Before you spend $3-4K, have a look on auction sites
eBay, Craigslist, offer up/let go & Facebook marketplace
We just bought a private labeled fletcher 3100 for $400. It needed the "repair kit" and the hold down strip. For $165 we saved $3000.
I listed the auction sites in order of descending price
We love the fletcher, by the way
We also bought a fletcher 2100 for $200 & gave my Logan away to a friend
Boudica
We have one that is terrific. I can't recall off the top what brand, I will look on Monday. Cuts ACM like buttah, clean smooth edges.
FireSprint.com
Trade Only Screen & Digital Sign Printing
Our steeltrak has been pretty good. We don't use it much anymore, but it always has a place in our shop. Keeping them in square is the key to it all. Here are a few to consider.
tulsagraphics
I have several of the FSCs. They're great! You can cut .063" aluminum / 3mm ACM -- but I wouldn't attempt 6mm. That stuff is way too thick/dense for a pizza wheel cutter.
zspace
We have a fletcher and a keen. They are both good choices but have slight differences. The keen hold down is more solid for acm and aluminum. The Fletcher is much faster for cutting down coroplast and cardboard. A panel saw would be a much better choice for 6mm ACM and heavier aluminum.
We added a used 100" fletcher gemini (got it for $300). Ordered the maintenance kit before i drove half way across pennsylvania to pick it up. what a great cutter! We also have a 40" guillotine table & a 63" roto trim chinese lookalike ( and a home made panel saw).
