Weird Corel issue
Discussion in 'Corel' started by mfatty500, Jun 26, 2020.
  1. mfatty500
    mfatty500 Active Member
    793
    90
    28
    May 10, 2010
    Sugar Grove, Ill
    I'm using x7, and while reading something on the net, all of a sudden the software decides to quit working, while i wasn't even using it, the last time I used it was last night. Any ideas why? I'm running it on Windows 8.1
  2. jimmmi
    jimmmi Member
    219
    8
    18
    Sep 13, 2013
    Athens Greece
    Corel is always in "beta" mode. Strange quits, sudden errors etc. Just save your workspace and reinstall.
  3. JBurton
    JBurton Signtologist
    1,899
    380
    83
    Sep 28, 2017
    Arkansas
    I know every time I put an oversized bmp in corel, it will bog down the whole system every 10 minutes when it does an autosave. Did you have a bunch open, or large document open when this happened?
    Also I wouldn't put it past 8.1 as the culprit!
  4. myront
    myront CorelDRAW is best
    1,492
    289
    83
    Dec 3, 2015
    Niceville, FL
    way too many variables that could cause all kinds of stuff. I'm using X7 with WIN7 and it's rock solid.
    Tips - check virtual memory settings
    Turn off auto-save
    Dump temp files often - I use a batch file that kills corel/dumps the temp files then restarts corel.
  5. mfatty500
    793
    90
    28
    May 10, 2010
    Sugar Grove, Ill
    corel has run just fine on 8.1, this happened again this evening, i only had 2 windows open at the time. yes myron i delete the temp files every morning. i/ve never had a problem until now.. what would turning off auto-save have to do with it?
  6. WildWestDesigns
    WildWestDesigns Major Contributor
    6,570
    324
    83
    Sep 27, 2010
    5
    I have a program (that actually interfaces with DRAW directly (only reason why I actually have DRAW in the first place)) and if "you" let the backup files take up so much room, it can wreck havoc on how reliable the computer is, including random crashes. Now Corel, may not suffer from the same problem, but that is just my experience with backup files that can cause system instability. Not something that would cause me to turn off auto backups, as that has saved my bacon on more then one occasion why I was using that program, but it did make me get into a regime of culling the backup files every so often. I would suggest that more so then just turning off the auto backups in their entirety. If that even does have something to do with your current issues.
    • I Appreciate You I Appreciate You x 1
  7. mfatty500
    793
    90
    28
    May 10, 2010
    Sugar Grove, Ill
    Thanks for the replies, it very well could have been the temp files causing this, when I emptied it this morning, it was showing that there was more than 12,000 items associated within the 43 items to be dumped, even though i emptied the temp files Friday morning.
  8. printhog
    printhog Member
    383
    169
    43
    Dec 15, 2010
    california
    Corel has background tasks option with x7.. turn that off. its not the same as backups, its a way of allowing you to work while its doing stuff in the background. if you try too many functions in succession while its running one in the background, like saving a file, it will just black out.
    • Like Like x 1
  9. KrisMalby
    KrisMalby New Member
    9
    May 14, 2020
    UK
    only semi related but iv just updated to corel 2020 and its a lot better than x7 or x8 for reliability anyway in my opinion, but windows 8.1 hasnt got a great rep in fact everyone i know hates it so i agree with JBurton with that.
