not sure about your software, but i know it's a stripped down version of flexi. Do you have a box opened up called design central or fill stroke editor? if so thats how you check to see if they are the same. Also if you select an item and look in the lower right hand corner of your monitor, it will show you a couple boxes that show the attributes of the fill and stroke.
Hope this helps,
Kevin
