Well, this is a new one...
K Chez
Had a real odd one yesterday, had a 60" wide graphic printed, lammed and on the cutter, set up as a segmented cutting job with three sections. Job started and was running fine, so I went back to cleaning up the truck to letter. I come back and the cutting is done - I take it out of the machine and notice something's not right- lots of letters in places where they shouldn't be. The first two sections are spot on but the third is the last section from the last job that ran! WTF! Has anyone ever had this happen?
myront
CorelDRAW is best
Did you check the cut file to ensure there wasn't erroneous stuff mixed in the background? i.e. text with not outline or fill set
That's usually a cross-firing in your software to printer connection. Check your ethernet.
