What bit should i use to cut corrugated plastic on cnc?
Discussion in 'CNC Routers & Engravers' started by 0igo, May 15, 2020.
  1. 0igo
    0igo Active Member
    539
    18
    18
    Mar 22, 2014
    Stockton Ca
    Does anyone with a cnc know if its possible to get clean cuts out of corrugated plastic on a cnc machine? i cut it using an spiral upbit and it left the edges ugly. maybe i went to fast? is there a bit that you guys have used that works?
  2. JBurton
    JBurton Signtologist
    2,200
    493
    83
    Sep 28, 2017
    Arkansas
    If I remember correctly, you want to go the opposite direction than what the bit manufacturer recommends. Try cutting a straight line and see if one side cuts cleaner than the other. I run a 1/8" belin single flute upcut on almost everything, but it leaves trash on the coro edges too.
    Ideally you get a tangential knife attachment and it will give perfect cuts.
    • Like Like x 2
  3. Raum Divarco
    Raum Divarco Application Specialist CWT / Amcad & Graphics
    64
    17
    8
    Feb 23, 2017
    US
    while is generally is better to cut with an oscillating tool, there are router bits for honeycomb materials etc. that are applications for straight flute tooling.
    you might also want to look into more cnc endmills that have many small teeth.
    you might find limitations depending on shank size etc.
    • Like Like x 1
  4. ikarasu
    ikarasu Very Active Member
    2,071
    660
    113
    Jun 10, 2016
    Port Coquitlam, bc
    The flutes are thin plastic that just get pushed around.... We've never had luck cutting it perfect with our router. Even the drag knife does the same thing in certain spots.
    We have a soldering iron we run across the edges that look bad.... The plastic is so thin it just melts off. It's been the easiest way we can find to clean it.
    • Like Like x 2
  5. 0igo
    0igo Active Member
    539
    18
    18
    Mar 22, 2014
    Stockton Ca
    Thank you for this I almost bought that knife tool...they’re expensive also lol. Luckily I’m just cutting out a big outline of my sons face so I guess I’ll just clean the edges.
  6. zspace
    zspace Merchant Member
    136
    44
    28
    Jul 9, 2013
    Houston, TX
    We haven’t found a router bit that cuts coroplast well. Reciprocating knives are the way to go for CNC. If you don’t have one,then for a short run you would do better hand cutting with an exacto knife. For a large run outsource it.
    • Agree Agree x 1
  7. MoultrieMade
    MoultrieMade Member
    28
    10
    3
    Jul 15, 2017
    Moultrie, GA
    I have had good results using a Donek drag knife with X-acto blades for 3mm coro. I edit my cut file to soften any inside corners. This eliminates the need for the knife to raise up in Z to make a sharp turn. I do the same for outside corners, or add loops if I want them to stay sharp. I'm generating my tool path with the drag knife gadget in Vectric Aspire.
    I've only done a few jobs with 6mm+ coro, but a 1/4" O-flute bit seemed to give the best results there. The corrugations were heavy enough for the bit to cut them rather than fold them over like it does in the 3mm material.
  8. johnnysigns
    johnnysigns Very Active Member
    1,199
    4
    38
    Nov 3, 2004
    East Coast
    Higher feed rates seems to help on coro. A new sharp tool also really helps. I can dig up feed rates we've used from our CNC if you need a baseline.
  9. Reveal1
    Reveal1 Active Member
    697
    236
    43
    Nov 7, 2010
    Cape Girardeau, MO
    Looks like you lost a few fingers on the router there 0igo.
  10. White Haus
    White Haus Formally known as RJPW..........
    739
    209
    43
    Apr 6, 2018
    Winnipeg
    Would love to check it out if you get a chance to dig this up. Thanks!
  11. johnnysigns
    1,199
    4
    38
    Nov 3, 2004
    East Coast
    We use these speeds at different depths for either perimeter/through cuts or scores for folding at a lesser depth. I believe I got some of this info many years ago on here from Typestries who was nice enough to share it. If you're comfortable with your machine moving at faster feed rates you can scale the RPM up to match. We use a simple feed rate calculator I downloaded online somewhere. I'm sure if you google: cnc feed rate exe some links should pop up to grab one.
    0.250" Tool Single Flute Upcut
    10500 RPM at 400 IPM with a plunge of 100 IPM
  12. Christian @ 2CT Media
    Christian @ 2CT Media Major Contributor
    4,734
    764
    113
    Jun 15, 2009
    Mesa, Arizona
    Compression bits work well as long as the compression is in the gap.
