What brand of vinyl do you use?
Discussion in 'Polls' started by kevco, Aug 18, 2005.
What vinyl do you use?
Poll closed Sep 17, 2005.
  1. avery
    23.7%
  2. oracal
    64.0%
  3. arlon
    12.3%
  4. 3m
    31.6%
  5. permagloss
    0.9%
  6. mactac
    7.0%
  7. shine rite
    1.8%
  8. gmi
    6.1%
  9. banner cal
    0 vote(s)
    0.0%
  10. other
    15.8%
Multiple votes are allowed.
  1. kevco
    kevco Guest
    While writing my reply to the avery topic I thougt it might be kinnda neat to see what every body else is using.
    [​IMG]
  2. Marlene
    Marlene Major Contributor
    10,970
    264
    83
    Jun 8, 2004
    Vermont
    I use Gerber 220 series which is made by 3M for Gerber. I've never had a problem in 18 years of using it. It's has always done what it is made to do and has never let me down or made our company look bad in anyway. I wanted to try Avery just because the color selection was really good (Gerber's color selection is lacking and hasn't been updated for years). I'm glad I never did try Avery and thanks my lucky stars for this site and all the members who posted issues so I didn't end up with problems.
  3. 7oaks
    7oaks Active Member
    509
    3
    18
    Aug 12, 2004
    LOUISIANA
    Did a sign last summer with 100% avery A8--next day I
    read about the fiasco. Looked at it the other day-zero shrinkage. Not a glue line anywhere
    Ken
  4. xtremegraphics
    xtremegraphics Member
    277
    Always use Avery , never had any problems yet!
  5. slappy
    slappy Very Active Member
    3,927
    3
    38
    May 31, 2005
    Earth
    I use Avery and Kapco. Not problems with either
  6. ChiknNutz
    ChiknNutz Major Contributor
    4,789
    2
    Oracal 651 & 751 (primary); Arlon 2100 HiPerf; 3M 7025, 7725 & Gerber 220 for cut vinyl.
    For printed stuff, so far I am using Oracal 3165 and 3651. I plan on using some 3951 for wraps along with compatible overlaminates (210, 215 and 290).
  7. JT
    JT Member
    302
    :thumb: I like to use Oracal 751. In the past I have used Neschen 2 mil Pro Cast. Haven't had any problems with either.
  8. gtjet
    gtjet Active Member
    763
    Type of vinyl we use
    We use 3M, Roland media for the versacamm and FDC vinyl mainly.
  9. ENTDesign
    ENTDesign Very Active Member
    1,050
    I have used Kapco, the only thing I don't care for is the thickness, always seems to be the hardest stuff to weed. I find Oracal 651 less difficult to weed than Kapco, but otherwise ok. Also use FDC and General Formulations (which I think is unbranded FDC) which weed very easy. I am going to be trying some Colburn fluorentine gold on a window job this week.
  10. Derf
    Derf Very Active Member
    I just started using Hexis and its good stuff so far, I also use Vector and Oracal
  11. Ken Beyer
    Ken Beyer New Member
    6
    I use mostly Avery 6 and 8 depending on the application. My only failure with this is when ( as a newbie) I applied vinyl to a latex painted surface. I've only been at it 2 years though. I was using metamark MD5 for printed stuff on the versa-camm and have recently been trying the Oracal 3651 print media. I find it is noticably less white than the Metamark MD5. Haven't tried the new MAX inks yet..
    Ken Beyer
    Signs That Work !
    Eagle Bay, BC
  12. kevco
    kevco Guest
    As my pole draws to a close I just wanted to thank everybody who partisapated.<sp>
    [​IMG]
  13. thesignshop.ws
    thesignshop.ws Member
    39
    Was using Avery only until a whole city of police vehicle had to be redone and no help from Avery. Don't care what they do in the future I will never return. Use Oracal 651,851,3651, and 3951
  14. PMG
    PMG Very Active Member
    2,453
    Used Neschen in the past,I now use Universal Products and Oracal 851,
  15. k.a.s.
    k.a.s. Very Active Member
    1,411
    4
    38
    Aug 8, 2003
    NE ohio
    I use Oracal 651 & 751, and I have started buying some Accucut from Trim USA. I have had good success with both.
    Kevin
  16. OldPaint
    OldPaint Major Contributor
    Shinerite
  17. justgraphics
    justgraphics Member
    175
    1
    Shinerite from Fellers also!
  18. iSign
    iSign Major Contributor
    13,027
    31
    48
    Nov 29, 2003
    Kahului, Maui
    Arlon Kalon
  19. kevco
    kevco Guest
    When I did this pole back in Aug. I was using Orcal for hi-per and permagloss for inter. Well OP talked so highly of shine-rite that I tried it shortly there after. I love the stuff! Thanks OP
  20. Flame
    Flame Major Contributor
    8,283
    7
    38
    Apr 26, 2006
    Vancouver
    Like a lot of people on here, I try to stick with Oracal. The stuff is dirt cheap and good quality. I use almost their entire range of calendered vinyls and then keep 3 different styles of their digital printing media in stock, plus laminate. Great stuff.
