mkmie
Lost Soul
Yep, Seems costly at first but saved many a print here.https://www.fellers.com/fellers-sho...nd-supplies/set/one-pass-dust-removal-rollers
We have two of these, one is the smaller version. Indispensable.
We use one and its just like the rest of these options. It does not get everything and static will still screw up your lams no matter how many passes you give it. It does have a slightly tacky surface and is easily cleaned by rolling it over scraps of vinyl with the adhesive side up. As for those who say it is expensive... I've been using it for 10 years. I don't know how long the shop had it before but at 10 years and a 1 time cost it's not that hard to do the math and come to the conclusion that it's the cheapest option for those shops that plan on being around for a while.The Fellers thing, interesting (and expensive) but if it does the job it may be worth it, does that have a tacky surface?
They get used on fresh base coat before clear, that's much more risky than a cured print. It's a staple product in the autobody industry and there really is no substitute. I'm surprised more people are not using them. A tack cloth will actually retain the trash it picks up and you don't have to worry much about it being redeposited on a print. Drop it on the ground, pick it up and flip it around, no big deal. My experience with the swifers is that they dont pick anything up except for fine dust and tear really easily if you hit the edge of the paper which leaves fibers.Tack cloth, seriously, maybe I don't know what that is but the last one I bought there is not a chance in the world I would touch it to an unlaminated surface, what am I missing?
I am also looking for good methods to do this. We used to just whip down panels with paper towels. Now I am using microfiber towels but I am having an issue with getting shocked every damn time. Do those rollers cause any static shock?
Exactly. I have a Roll-X table with a cutting mat and when I whip it down with a microfiber cloth I get a shock from the side of the table right on the head of my you know what. I was hoping that blue roller doesn't promote static and if I can add a small extension pole to it.I never get shocks with the tack cloths as I'm laminating, but I'd assume they create a little static since anything moving on a surface will create static to an extent. I used to get shocked like crazy using microfiber cloths on materials on our table that's got a self healing mat on it, until I figured out to put a finger on a screw in the table and that grounds me out.
The pad will last you 6 months to a year, depending how much you use it. If you can't figure $30 in to your cost of goods for over a year....lol, and the extra pas are $30.
We do the same thing in using scrap vinyl/laminate to clean off the roller. Also, a rinsing in the sink with straight water will get off the hard to take off specs of stuff that sticks to the roller.We use one and its just like the rest of these options. It does not get everything and static will still screw up your lams no matter how many passes you give it. It does have a slightly tacky surface and is easily cleaned by rolling it over scraps of vinyl with the adhesive side up. As for those who say it is expensive... I've been using it for 10 years. I don't know how long the shop had it before but at 10 years and a 1 time cost it's not that hard to do the math and come to the conclusion that it's the cheapest option for those shops that plan on being around for a while.
For the lazy ones... or those bad at math... $185/10years= $18.50 per year $18.50/12months= $1.50 per month $1.50/22working days a month= $0.075 per day. Its a great option IMHO
https://www.ebay.com/itm/Sticky-Sil...ust-Clean-Remover-Car-Vinyl-Tool/173624106954$185? WTF? Is it not just a static roller with sticky pads?
Yeah, see this is my point. Exact same thing with the helium trades. Taking a "medical grade" product and selling it to other industries with the same price saying "well this is just how it is." When obviously it can be sold for much less. These rollers appear to have come from medical or scientific clean room needs and carry that inflated price across other industries. Microfiber towels work just fine for our needs and if someone wants to compare math, we spend way less than $18 a year on them.
I had a client who placed a big tent in her warehouse as a clean room environment with vacuum blower to suck out any dust inside the tent. She also wears a suit before going in. Inside the tent includes the laminator and printer. Cleaning roller with extended handle is used to prevent close body contact from the print. Works for her.What do you guys have the best luck with getting dust, hair, etc off prints before you laminate.
Sometimes mine are great and then often enough I find a hair or dust caught under laminate.
OK so I have tried a few things...
Fabric Softener Sheet (feel that leaves something gritty on media, is there a particular kind)
Swifter Duster (I like this but once it gets hair or dust on it I feel it drops it later)
Microfiber towel (Don't use this a lot but leaning this way)
What do you use, and do you have a particular method?
Thanks!
