What is the largest size heat transfer you can press on a 16 x 20 press?
blacknbart
Doing some costing and just wanted to know what's the max size you could do on 16 X 20 Press.
Thanks for the advice!
royster13
If it is cold peel, you can tile your presses so size is almost unlimited.....If they are hot peel I try to keep 1" in from edge so I would only do 14 x 18 on a 16 x 20.....However, the better the press the closer to the outside you can press.....
