What is the smallest letter I can cut?
Discussion in 'Dimensional Signs' started by wraprat, Oct 20, 2010.
  1. wraprat
    wraprat New Member
    12
    Sep 1, 2010
    deerfield beach florida
    I using a Vision 2550 Router trying to cut a 2" letter out of 1/8" acrylic and having all kinds of trouble with the letters moving even though i have the acrylic double face taped down. Whats the trick or is it possible?
  2. SignManiac
    SignManiac Major Contributor
    8,494
    37
    48
    Mar 25, 2006
    Mars Florida
    slow your feed rate down for starters.
  3. jiarby
    jiarby Major Contributor
    4,513
    the smallest letter you can cut is a lower case "i"
  4. astro8
    astro8 Active Member
    778
    17
    18
    May 23, 2009
    Sydney, Australia
    I've cut a lot of letters 1/2" and smaller in 1/8" and even 1/4" acrylic with a 1/16" bit on the router before we got the laser. Slow down your feed rates, set your z height so you cut the letter but leave the masking (paper/plastic protector) intact and that will hold the letters.
    If you can set your dust extractors head to ride on the material that will help with lifting. Use your vacuum bed if you have one.
    2" letters should be a piece of cake.
    Hope this helps.
  5. wraprat
    wraprat New Member
    12
    Sep 1, 2010
    Thanks for the info much appreciated!
