What kind of grease on Carriage bearings?
Graphics2u
What kind of grease do you use on the bearing raceways? Will Lithium Grease be alright? I know it doesn't take very much at all.
Slack11
I used lithium grease last nite, and it worked fine. You're right the very little you use I figured Lithium would be allright.
Checkers
Check with the manufacturer.
With some machines, oiling the bushings may do more harm than good.
Checkers
Graphics2u
Mutoh sells their own grease for it, but it can't be anything special.
Is 3-1 able to stay on the rails with out dripping off?
poslive
I tried lithium grease on my Toucan LT raceways and it dried and left chunks of crud behind. I've since switched to silicon; just spray some on a foam swab and wipe down the track.
John Butto
Ace Plumber's gease
in a small tube at Ace Hardware, for bearings and sliding surfaces, resist temperatures, works great on the 1204
bob
When you say raceway do you mean the inner and/or outer bearing race, the cylinders between which the actual bearings ride, or do you mean the ways upon which the outer race of the bearing travels?
If the former, a wee bit of silicone or 3-in-1 oil assuming the bearings are not sealed.
If the latter, do nothing but clean the ways. There is little or no friction on a roller riding a way and lubrication does little but make a mess. Just make sure that the ways and the outer races of the bearings are always clean.
