Question What length roll do you run in your 64in Printers?
Discussion in 'Hewlett Packard' started by bannertime, May 19, 2017.
  1. bannertime
    bannertime "You guys do banners, right?"
    649
    124
    43
    Sep 8, 2016
    DFW
    In the HP 300/305 Series the roll weight limit is 92.6lbs. We've been running 90ft lengths of 63in material for the sake of ease, and it falls well below that limit. I've tried two rolls of 165ft lengths of 63in and while it runs fine, there are some stress noises. The 63"x165' comes in at 97lbs, with packaging. according to a UPS label. Last time I cut off about 25ft for some cut vinyl banners and then the rest went through the printer. This time it was loaded directly in. Probably won't use that length anymore unless people have been consistently running it.
    So, I'm just curious what length 13oz material people are running.
  2. SkyHighJK
    SkyHighJK Member
    We'll run rolls that are 63" x 150' on our 360/365 ....
    Besides the physical effort of actually loading the roll itself, we've never experienced any issues. Those weight limits are there for safety purposes and to make sure the user doesn't do anything crazy; in actuality I wouldn't be surprised if you can go over it by 10 or even 20%.
    -Jordan
  3. SkyHighJK
    SkyHighJK Member
    ........That being said, it sure is a pain to deal with 100 lb rolls!!
    -j
  4. electricfly
    electricfly New Member
    10
    Apr 17, 2010
    Boston MA
    Also use the shorter rolls as we don't do a lot of banners.
    If I was printing more would go with the longer rolls
  5. 2CT Media
    2CT Media Very Active Member
    2,791
    201
    63
    Jun 15, 2009
    Mesa, Arizona
    We are now running 54" x 300' Rolls of SAV from Avery in our 360. They are 95lbs and 9" diameter.
    Biggest roll of Scrim we run is 63" x 115' of 15oz Blockout and it weighs in at 93.5lbs.
  6. bannertime
    649
    124
    43
    Sep 8, 2016
    DFW
    It isn't fun having to move around a 97lb roll. My horizontal racks aren't meant for it, so I have to move it from vertical storage to horizontal. Definitely easier with two people, but I've done it myself. Only 15oz I use is 38" and my SAVs are just 54" so this was the only roll I use that's longer than 54". I typically only go through about two of the 64" rolls a month, so it's not like I'm having to change it out every day.
    I started thinking about it, and I'm wondering if that 92lbs was specifically for the loading tray. Didn't have any issues printing from the full roll of 165'. It's a better deal than the 90' rolls and actually seems to be a better material than Forward banner. So we'll probably keep using it. Thanks for the info guys.
