What material are solvent o-rings made of ?
sfr table hockey
I need to buy some solvent resistant o-rings .Does anybody knows material that is solvent resistant? I was looking at this website http://www.marcorubber.com/material_chart.htm where they have a lot of material choices. Thank you.
Not sure on the material but,
In a pinch you can try this if you have no orings and need something to seal the line:
Take the pump tube line and cut just a 1/16 to 1/8 inch off. It is usually just the right diameter tube to go over the ink line inside the brass nut. Have never tried it but in a pinch.... its good to know.
