Teckwin Teckstorm
we always print at 720x720 8pass uni-dir for CMYK and bi-dir for W. High-speed with 1mm to 1.2mm carrige height from substrate.
Our own profiles for each substrate of course.
Most of people printing on large format printers may not take advantage of RIP software fuctionality fully as they should. Taking a pre-made profile as tweaking it most of the time can do the trick for many substrate without spend great deal of time and trial in profiling process.
(Think of rich people who do not own the jet plane, instead they join the Exclusive Jet Club instead of having their own pilot, air port, etc. Likewise, you may not need profiling software or hardware if you can tweak the existing profiles and adaptation to use with your new media)
Creating your own profile is no cake walk to do it correctly you will need to have Good Inks to start with, RIP Software that can understand the profile which you about to create, and the Profile Maker Software , and Profile Maker's hardware such as spectrometer and colorimeter, etc. And the substrate you want to profile.
There are schools or service calls just on this topic and most of the time, it is beyond the scope of the technicians which they only know the hardware and maintenance but not the digital color management in relate to printing and profiling.
For example, if you own JV3 or JV33 you will need the buy the Profile Maker Software and buy Spectrometer/Colorimeter to front with your profiling battle. And do countless of spot color metering to achieve the best results on each printing PASS set such as Uni-direction, Bi-direction, 4 Pass , 8 Pass, etc. Also dealing with density adjustment, color balance, color replacement when your inks doing funny dripping, and trail prints to acheive a set of good working profile for a particular media that you want to secure printing quality. If you using none-oem inks, the adjustment will seem to be endless and the consistancy of the ink is vital to result of your profile. (Inks do have elastic fluid mix properties when jet, and also have viscosity properties when drying, these are factors for your adjustment on your PASS type and PASS mode when profiling)
Once you have your profile correctly measured and satisfied, you can virtually print at maximum speed that you can pround of speed, and quality , everytime!
FlexiSign Pro, PhotoPrint Pro, Wasatch, and Onyx came built-in with Profile Maker function and can connect to the supported hardware so you can create your own profile using all in one software to achieve that, but be warn; it is not that easy! Tweaking the existing profile will give you the shortcut. Unless you have particular stubbon media that it need to be dealt with absolution.
