What Vinyl should I use for Trailer Graphics?
Discussion in 'Vehicle Graphics' started by Juan C Torres, Jun 3, 2020.
  1. Juan C Torres
    Juan C Torres Lets print
    3
    Apr 22, 2020
    Orlando, Florida
    Hi everyone . What Vinyl should I get to print the pictures graphic on this trailer? I have 3165ra but not sure If is good for this side panel . ( Just the pictures graphic because I am using cut vinyl for the letters). Thanks in Advance.
    [​IMG]
  2. CanuckSigns
    CanuckSigns Very Active Member
    3,509
    430
    83
    Nov 11, 2008
    Ontario
    Since the trailer has rivits, I would use a cast wrap film like 3M IJ180 or similar.
  3. Jester1167
    Jester1167 Premium Subscriber
    My personal opinion would be to use cast vinyl with a cast laminate. Because we don't have freezing cold in Florida you could get away with a high performance calendared vinyl.
    Because we are supposed to be professionals, I take the cost of entire process into account for my clients sake and that includes removal. Avery and 3M are a tie. Avery gets the edge in installation ease and 3M gets the edge in removal. I tend to shy away from Orafol because of past removal experiences.
    All in all Avery 1105 and their 1460 cast lam is my go to because with proper techniques it well stay in the window recess of a sprinter or transit connect, and, it's cheaper than 3M as well.
  4. Reveal1
    Reveal1 Active Member
    631
    203
    43
    Nov 7, 2010
    Cape Girardeau, MO
    Good points - but we spend 1/3 of the year wrapping trailers in cold warehouse (45-50 with the portable heaters going) and find that in those circumstances a higher tack product works better . We use Arlon 6100 which is cast but at lower end cost-wise and has higher initial tack. Also good for print/cut.
  5. Billct2
    Billct2 Major Contributor
    7,517
    660
    113
    Mar 12, 2005
    New England
    Cast vinyl and laminate. And I would revisit the color choice, the only thing anyone is going to notice is the photo montage
    • Agree Agree x 2
  6. d fleming
    d fleming Very Active Member
    2,805
    238
    63
    Nov 28, 2007
    Middleburg, Florida
    Cast and lam, air egress. Looks like screws not rivets. If so, I normally remove screws apply graphic then replace. To me it just looks better than going over.
