Whats an easy way to do dropshadows?
Discussion in 'Adobe' started by Pulskamp, Sep 3, 2003.
  1. Pulskamp
    Pulskamp Member
    33
    I stumbled across a good way, only a few steps to cuttable, in the pathfinder pallet, but I can't seeem to do it again:help: Any ideas? what works for you?
    TIA!
  2. Baz
    Baz Very Active Member
    Take the shape you want to drop shadow. Copy - Paste ( position it where you want ) - Then "Paste in front" the same shape again - Then use the pathfinder weld otpions to perform your weld or cut command to the bottom shape and the copy which is positioned exactly over top the original.
    For multiple shapes ( Like a lign of texte ) you have to convert each of the copies you made to compound paths for the weld to work properly.
  3. Pulskamp
    Pulskamp Member
    33
    cool, thats what I was doing. just thought that somebody might have a better way.
