Need Help What's Going On Here? (SOLVED)
PrinterPower
Unoffical Printer IT
Good afternoon,
I seem to be having a problem with my Roland Soljet Pro III XC 540. I'm trying to print a 25.2' long banner and while VersaWorks (version 5.5.1) shows the artwork and all my settings, what essentially happened is that the printer rolled out all 25.2' but didn't print anything on the banner material. Then it was ready to print again.
Am I missing some limitations somewhere? Or some settings? I don't know what kind of banner material I'm using (not in charge of ordering) but I've never had this problem before with 72" banners. The height of the banner is only 2.6'. Thank you!
PrinterPower
I forgot the mention that the file I need to print is saved as a PDF. Also, Versaworks only showed 200" of the file in the display instead of the full 302", is that just a display limitation?
Vohaul
It’s your PDF..... PDF can’t go any bigger than 200 inches (or somewhere close to that)
If you try to export it from illustrator or Corel etc, it’ll just be a blank file....
Make your art final size 50% of the final and do then scale it up 200% scale in versa
PrinterPower
Thank you, I will keep that in mind and give a try!
