What's the perfect resolution for a larger poster print?
Discussion in 'Digital Printing' started by graphic24, Jul 4, 2019.
  1. graphic24
    graphic24 New Member
    7
    1
    3
    Mar 23, 2019
    Dhaka,Bangladesh
    On the occassion of "Natonal Mourning Day", I need to print 50, 000 larger posters. But I need to know about the the perfect resolution for a larger poster.
  2. alex242
    alex242 New Member
    16
    4
    3
    Feb 27, 2013
    Chile
    1:1 72 DPI, but depends of the image's quality.
  3. 72 DPI is more than enough
  4. burgmurk
    burgmurk Member
    139
    22
    18
    Oct 24, 2016
    Auckland, New Zealand
    some people think an A3 is large...
    i'd agree 72dpi is 'enough' if the poster is A1 or bigger. i'd say minimum was 150dpi if it's smaller than a1.
    'perfect' resolution? 600dpi :p
  5. Baz
    Baz Very Active Member
    If it's just an image 72 dpi is good enough.
    If it has text then my preference is 125dpi.
  6. Joe House
    Joe House Active Member
    972
    217
    43
    Feb 5, 2004
    WA
    I don't know about perfect, but I've always recommended 100 - 150 dpi at full size and you'll usually be satisfied with the output. (All bets are off though if you're printing for a bunch of picky printer operators with loupes in their pockets ;))
    • Agree Agree x 1
  7. Jburns
    Jburns Active Member
    790
    156
    43
    Jan 19, 2009
    Denver
    Doesn't the viewing distance matter?
  8. Joe House
    972
    217
    43
    Feb 5, 2004
    WA
    I think that "Posters" tends to indicate a 5' plus viewing distance. You are correct though, if this were for a POP display at a cash register with a 1 foot viewing distance, you'd want to bump it up somewhat.
    • Agree Agree x 1
  9. shoresigns
    shoresigns Very Active Member
    1,533
    299
    83
    Nov 1, 2011
    Vancouver, BC
    Bingo. You can't determine the perfect resolution for a print unless you know the viewing distance. Here's the formula:
    resolution (ppi) = 600 / viewing distance (feet)
    So based on the size of the posters and the place where they'll be hung, estimate how far back people will normally stand to look at the posters. Say you come up with 12 feet, plug that into the formula and your resolution needs to be 600 / 12 feet = 50 ppi.
    • Like Like x 1
  10. Solventinkjet
    Solventinkjet DIY Printer Fixing Guide
    4,295
    808
    113
    Aug 2, 2011
    Denver, CO
    1:1 72dpi for images and don't rasterize vector art or text. Badabing bada boom. As for viewing distance, as long as you don't rasterize your vector art/text and your images are 1:1 it doesn't matter. If anything you would downsample some of your higher resolution images to lower file size and RIP faster.
  11. DesireeM
    DesireeM Member
    354
    4
    18
    Jan 31, 2012
    Sudbury, Ontario Canada
    Is the artwork all vector or are there raster elements? You can only go as high for resolution as your highest resolution original raster element. So if you have a stock photo original at 600 dpi and the rest of the layout is vector I'd go as high as I could(in this case 600dpi) - assuming only a couple feet or less viewing distance. But if your raster element is only 72 dpi to begin with, then 600dpi will just "blurr" the missing pixels.
    Even if everything is vector to begin with I would just go with 600dpi because it's better to have too may pixels than not enough. If you're not wasting too much time in file-saving or ripping/loading then I'd say go big.
  12. myront
    myront CorelDRAW is best
    1,506
    294
    83
    Dec 3, 2015
    Niceville, FL
    Exactly. That's why you want to use pdf. Vectors are preserved.
    I'd like to add another point here. Let your RIP do the resampling. i.e. No need to resample your images in your working file. Just do the layout with whatever image was given. Unless the image is of poor quality to begin with. If that's the case find something comparable or ask for a better one. Resampling and then trying to do your layout will make for HUGE files and bog your system down tremendously. Too many times I 've seen designers resample a 72dpi image straight from a decent digital camera and then take it into photoshop and create a tiff at 5ft &150dpi then proceed with their layout and ***** because it takes too long to do anything.
  13. Bly
    Bly Very Active Member
    3,107
    387
    83
    Mar 9, 2004
    Sydney
    150dpi
  14. KeithMan
    KeithMan Member
    43
    Sep 1, 2019
    Missouri
    Why would you even consider running this on an inkjet? Offset would be the way to go for that quantity.
    • Agree Agree x 1
